Cleaning belt sander belts after heavy use
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=52929
Author:  Michael Lloyd [ Wed Feb 12, 2020 7:37 pm ]
Post subject:  Cleaning belt sander belts after heavy use
After heavy use on the belt sander, especially with high resin woods, I'd use Easy-Off to soak the loose belt then rinse it in a bucket of warm water. It was always a messy job to do and clean-up.
So I decided to give it some thought for a better way and came up with this;
Using a piece of 4 1/2" PVC piping about 24" in length and 2 adjustable bands (a second modification). I now wrap the belts around the PVC pipe, spray with Easy-Off, let sit as directed then rinse with warm water and let dry.
No more messy cleaning and washing. :)
Author:  Chris Pile [ Wed Feb 12, 2020 8:12 pm ]
Post subject:  Re: Cleaning belt sander belts after heavy use
Old tennis shoes work well, as well as natural rubber blocks available at suppliers.
Author:  Ed Haney [ Wed Feb 12, 2020 8:18 pm ]
Nice tip, Michael. I've been tossing my belts at that stage. Thanks to you I now know a way to salvage them, if I'm not to lazy.
Author:  meddlingfool [ Wed Feb 12, 2020 9:19 pm ]
Hmm....
Author:  Hans Mattes [ Wed Feb 12, 2020 10:42 pm ]
Though I generally avoid recommending Harbor Freight products, they sell a "Sanding Belt Cleaner" that's inexpensive ($8.50) and really works. It's a block of crepe rubber (1.5" x 1.5" x 8"). I rub it across my still running belt or drum sander after I'm finished sanding and the paper comes remarkably clean -- even with oily woods or glue residue.
Author:  whiskywill [ Thu Feb 13, 2020 11:13 am ]
You can also use old silicone sealant which has set inside the tube. Remove the tube first, of course.
Author:  Ken Lewis [ Thu Feb 13, 2020 11:20 am ]
I'd be concerned about silicone, even cured stuff, creating problems for finishing
on anything that gets sanded by said sanding belt.
Curious as to what everyone else thinks...
Author:  Mike OMelia [ Thu Feb 13, 2020 6:29 pm ]
I have never seen anything that will take African Blackwood or Cocobolo off of sand paper. Post videos of ur stuff doing it. I use easy off. When I need aggressive sanding on those woods, I use 36 grit. Never clogs. Trick is knowing when to stop and switch to 80 grit.
Author:  Pat Foster [ Fri Feb 14, 2020 6:39 pm ]
m
Remember Hush Puppies? They work too. They had crepe soles.
